       << Click to display table of contents >> TrvActionCustomFileIO.CustomFilter |
Specifies the file filter for custom file formats.
property CustomFilter: TRVALocString;
This property allows opening, saving and inserting files in custom formats (in addition to the standard formats provided by RichViewActions).
Value of this property is appended to the Filter property of the file opening/saving dialog, if the action supports custom formats.
Default value:
'' (empty string)
See also:
