       << Click to display table of contents >> TRVAControlPanel.XMLLocalizable |
Specifies whether UI text related to XML format is maintained automatically by the localization procedures.
property RVFLocalizable: Boolean;
This property is used if XMLComponent is assigned.
If True, all text related to XML format is maintained automatically (i.e. localized text is used when UI language is changed).
If False, XMLFilter property is used.
Default value:
True
See also:
