       << Click to display table of contents >> TRVAControlPanel.XMLComponent |
Defines a link to a component allowing to load and save XML files.
property XMLComponent: TRVXMLComponent;
You can assign TRichViewXML component to this property.
If this link is defined, XML format can be used in TrvActionOpen, TrvActionSaveAs, TrvActionExport and TrvActionInsertFile actions.
See also:
