TSRVViewProperty.AutoVScrollBarPosition
Specifies where a vertical scrollbar is located if a right-to-left document is loaded
property AutoVScrollBarPosition: Boolean;
By default, if BiDiMode = rvbdRightToLeft, a vertical scrollbar is moved to the left side.
If you assign False to this property, this scrollbar will always be at the right side.
Default value:
True
