TSRVTabSet.Spacings
TSRVTabSet.Spacings
Specifies a distance between tabs.
property Spacings: TRVPixel96Length;
This value can be negative, if you want tabs to overlap.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
0
