TSRVBackgroundProperty.FillType
Specifies the background filling mode.
type
  TSRVFillType = (srvtfFlat, srvtfGradientH, srvtfGradientV);
property FillType : TSRVFillType;
Value
Meaning
srvtfFlat
A plain colored background, the color is ColorBegin.
srvtfGradientH
A horizontal gradient, the background is filled with horizontal gradient using three colors: from ColorBegin through ColorMiddle to ColorEnd.
If ColorMiddle = clNone, only two colors are used.
srvtfGradientV
A vertical gradient, the background is filled with vertical gradient using three colors: from ColorBegin through ColorMiddle to ColorEnd.
ColorMiddle is shifted by the percent specified in PercentMiddle.
Default value:
srvtfFlat
