TSRVBackgroundProperty.ColorBegin
Specifies the initial color of gradient filling.
property ColorBegin: TColor;
If FillType  = srvtfFlat, this property defines a background color.
This color is also used for background of zooming panel, if it does not use a gradient.
If VCL theme is active (in Delphi XE2 or newer), and this color is a system color, a corresponding theme color is used.
Default value:
$00E7BE9F
