TSRichViewEdit.RangeSearch
Allows to narrow a search scope.
RangeSearch: Boolean;
If it is True, the search is performed only in items located between coordinates specified in RangeSearchFirstY..RangeSearchLastY properties.
This range affects the following methods:
FindPriorItem, FindNextItem,
FindPriorHyperlink, FindNextHyperlink,
FindPriorCheckpoint, FindNextCheckpoint,
PriorCurItem, NextCurItem,
PriorCurHyperlink, NextCurHyperlink,
PriorCurCheckpoint, NextCurCheckpoint.
This feature can be used, for example, to search only on the some pages.
Example: searching for the first visible hyperlink (if any hyperlink is visible):
  RVData: TCustomRVData;
  RVData2: TCustomRVFormattedData;
  ItemNo, OffsetInItem: Integer;
SRichViewEdit1.RangeSearch := True;
SRichViewEdit1.RangeSearchFirstY := 0;
SRichViewEdit1.RangeSearchLastY := SRichViewEdit1.ClientHeight;
SRichViewEdit1.GetFirstItemVisibleRV(RVData2, ItemNo, OffsetInItem);
RVData := RVData2;
Dec(ItemNo);
if FindNextHyperlink(RVData, ItemNo) then
