TSRichViewEdit.FindNextItem
Finds the location of the next item of the specified styles (types).
function FindNextItem(StyleNo: array of Integer;
  var RVData: TCustomRVData; var ItemNo: Integer) : Boolean;
The search can be limited to the specified range of coordinates, see RangeSearch.
Input parameters:
StyleNo – a list of styles (types) for searching.
RVData, ItemNo – starting position for the search. The search starts from the next item. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData; if the cell is edited, it must be an inplace editor's RVData), ItemNo is an index of item in this document.
Output parameters:
RVData, ItemNo – position of the found item. Valid only if the method returns True.
Return value:
True if found.
Example:
  ItemNo: Integer;
  // searching for the first image in the document
  RVData := SRichViewEdit1.RichViewEdit.RVData;
  ItemNo := -1;
  if SRichViewEdit1.FindNextItem(
    [rvsPicture, rvsHotPicture, rvsBullet, rvsHotspot],
    RVData, ItemNo) then
See also:
FindPriorItem
NextCurItem
FindNextCheckpoint
FindNextHyperlink
