TSRichViewEdit.OnSaveCustomFormat
This event allows saving data to field in your own format.
type
  TSRVCustomFormatEvent = procedure (Sender: TSRichViewEdit;
     Stream: TStream; var DoDefault: Boolean) of object;
property OnSaveCustomFormat: TDBSRVCustomFormatEvent;
This event may be called:
in TDBSRichViewEdit
if Document is linked to a database field using LiveBindings
See the event of the same name in the TRichView help file (event of TRichViewEdit).
See also:
OnLoadCustomFormat
