rvsqldataprovider TRVReportSQLDataProvider [LCL]
Events
Events
A data provider receiving data from various SQL databases, for Lazarus.
Unit RVReportSQLDataProviderLaz;
Syntax
TRVReportSQLDataProvider = class (TRVReportCustomDBDataProvider)
hmtoggle_arrow1Hierarchy
Description
This component provides data for a report generator component from various SQL databases, including Firebird,Microsoft SQL Server, Sybase ASE, MySQL.
SQL select statement
table name (without space characters)
To use this component, assign it to DataProvider property of TRVReportGenerator.
TRVReportSQLDataProvider introduces the properties:
property Database: TDatabase;
property Transaction: TSQLTransaction;
Internally, the component uses temporal TSQLQuery components to handle data queries. The data provider properties and events are assigned to these components. If you want to assign additional properties to them, use OnDataSetCreated event.
In addition to the default query processing, you can provide another DataSet component in OnCreateDataSet event. This DataSet is not necessary needed to be TSQLQuery.
See also
Data queries
