rvpsqldataprovider TRVReportPSQLDataProvider [VCL]
Events
Events
A data provider receiving data from PostgreSQL databases via PostgreSQL components.
Unit RVReportPSQLDataProvider;
Syntax
TRVReportPSQLDataProvider = class (TRVReportCustomDBDataProvider)
hmtoggle_arrow1Hierarchy
Description
This component provides data for a report generator component from PostgreSQL databases via PostgresDAC components by MicroOLAP Technologies LTD.
SQL select statement
table name
To use this component, assign it to DataProvider property of TRVReportGenerator.
TRVReportPSQLDataProvider introduces properties:
property Database: TPSQLDatabase;
Also: ObjectView property.
Internally, the component uses temporal TPSQLQuery and TPSQLTable components to handle data queries. The data provider properties and events are assigned to these components. If you want to assign additional properties to them, use OnDataSetCreated event.
In addition to the default query processing, you can provide another DataSet component in OnCreateDataSet event. This DataSet is not necessary needed to be TPSQLQuery and TPSQLTable.
See also
Data queries
