TRVReportColorChangerItem.OpacityBegin, OpacityEnd, OpacityMiddle
These properties specify the scales of opacity.
property OpacityBegin: TRVOpacity;
property OpacityMiddle: TRVOpacity;
property OpacityEnd: TRVOpacity;
Cells are shaded with gradations of two or three opacities that correspond to minimum, midpoint, and maximum thresholds.
Opacities are defined in 1/1000 of percent, they must be in the range 0..100000.
OpacityMiddle is used only if ColorMiddle <> rvclNone.
An opacity corresponding the given value is calculated similarly to colors.
Default value
100000 (100%)
See also
ColorBegin, ColorMiddle, ColorEnd
PercentMiddle
