TRVReportBarVisualizer.Gradient
Specifies whether bars must be painted using a linear gradient fill.
property Gradient: Boolean;
If False, bars are filled with Color.
If True, bars are filled with a gradient from Color to a twice lighter color, in the direction specified in BarDirection.
For negative values, NegativeColor is used instead, and the direction may be opposite, see AxisPosition.
VCL and LCL: Gradient is used only if visualizers are drawn using GDI+ (in Delphi XE2+ and optionally in Lazarus).
Default value
False
