TRVReportBarVisualizer.AxisPosition, AxisColor
These properties specify the axis position and color.
type
  TRVReportBarAxisPosition =
    (rvrbapAuto, rvrbapMiddle, rvrbapSide);
property AxisPosition: TRVReportBarAxisPosition;
property AxisColor: TRVColor;
AxisPosition is taken into account only if MinValue < 0. Otherwise, all bars are started from a side (for example, if BarDirection = rvrbdRight, bars are started from the left side), and an axis is not drawn.
AxisPosition
Meaning
Example
rvrbapAuto
Axis position is calculated automatically from MinValue and MaxValue
Bars for positive and negative values are shown in the opposite directions.
BarVis_Axis_Auto
rvrbapMiddle
Axis is always at the middle.
BarVis_Axis_Middle
rvrbapSide
Axis is at a side (and is not shown)
Bars for positive and negative values are shown in the same direction
BarVis_Axis_Side
In the table above, examples use the following data:
-50
0
50
100
AxisColor specifies the color for drawing an axis line. If AxisColor = rvclNone, an axis is not drawn.
Axis is drawn on margins as well.
Default values:
AxisPosition: rvrbapAuto
AxisColor: rvclBlack
