TrvrActionInsertTable.UseDataTables
Allows using DataProvider to get a list of tables and their fields.
property UseDataTables: Boolean;
If True, and DataProvider is defined, the action displays a dialog for creating a report table basing on a data table.
Otherwise, the action displays the standard table insertion dialog to insert a blank table.
Default value:
True
