polarspellcheckinterface TRVAPolarSpellInterface
Allows using Polar SpellChecker to correct spelling errors.
Unit RVAPolarSpellInterface;
TRVAPolarSpellInterface = class (TRVACustomSpellInterface);
hmtoggle_arrow1Hierarchy
Description
To use this component, assign it to SpellInterface property of TRVAControlPanel component.
Properties:
PolarSpellChecker – a link to TRVPolarSpellChecker component. Assignment to this property is required, otherwise spelling check will not work.
See also:
RichViewActions spelling check interfaces
