<< Click to display table of contents >> TRVACustomSpellInterface |
A base class for RichViewActions spelling check interface components.
Unit RVADownloadInterface;
TRVACustomDownloadInterface = class (TComponent);
TObject TPersistent TComponent |
This component is not used directly. Instead, use one of the following components inherited from it:
•TRVAAddictSpellInterface (to use Addict)
•TRVAASpellInterface (to use ASpell)
•TRVADXSpellInterface (to use ExpressSpellChecker)
•TRVAHunSpellInterface (to use HunSpell)
•TRVAPolarSpellInterface (to use Polar SpellChecker)
To use a spelling check interface component, assign it to SpellInterface property of TRVAControlPanel component.
Then you can:
•use TrvActionSpellingCheck action
•use TrvActionThesaurus action (if the chosen interface component supports a thesaurus)
•call its AutoCorrectInKeyDown in the editor's OnKeyDown event and AutoCorrectInKeyPress in the editor's OnKeyPress event to perform auto-correction on typing (if the chosen interface component supports an auto-correction)
•assign the inverted result of its IsWordValid method to the Misspelled parameter of the editor's OnSpellingCheck event to perform a live spelling check.
Methods:
function AutoCorrectInKeyDown(Editor: TCustomRichViewEdit;
Key: Word): Boolean;
function AutoCorrectInKeyPress(Editor: TCustomRichViewEdit;
Key: Char): Boolean;
function IsWordValid(const S: TRVUnicodeString;
rv: TCustomRichView; StyleNo: Integer): Boolean;
virtual; abstract;
See also:
