TrvActionInsertHyperlink.ValidProperties
Defines properties distinguishing hyperlinks from normal text, if style templates are not used.
type
  TRVHyperlinkProperty = (rvhlBold, rvhlItalic, rvhlUnderline,
    rvhlUnderlineColor, rvhlStrikeout, rvhlColor, rvhlBackColor,
    rvhlHoverColor, rvhlHoverBackColor, rvhlHoverUnderlineColor,
    rvhlHoverUnderline, rvhlCursor, rvhlJump);
  TRVHyperlinkProperties = set of TRVHyperlinkProperty;
property ValidProperties: TRVHyperlinkProperties;
This property is used only if style templates are not used (i.e. the target editor's UseStyleTemplates=False). If style templates are used, the action applies StyleTemplateName instead.
When this action converts text to hypertext, properties of this action listed in this property are applied:
BackColor
Color
HoverBackColor
HoverColor
HoverEffects
HoverUnderlineColor
UnderlineColor
Style
When this action converts text to non-hypertext, properties of RVStyle.TextStyles[0] listed in this property are applied.
Default value:
[rvhlUnderline, rvhlColor, rvhlBackColor, rvhlHoverColor, rvhlHoverBackColor, rvhlCursor, rvhlJump] (hyperlink with the standard hyperlink cursor, blue and underlined)
