TrvActionInsertHyperlink.HoverBackColor
Defines the background color for hyperlinks under the mouse pointer.
property HoverBackColor: TColor;
This property is used only if style templates are not used (i.e. the target editor's UseStyleTemplates=False). If style templates are used, the action applies StyleTemplateName instead.
This property is used when converting text to hypertext, if rvhlHoverBackColor is included in ValidProperties.
A value of this property can be changed by the user in the hyperlink properties dialog.
Default value:
clNone (transparent)
