RVA_GetProgressMessage, RVA_GetPrintingMessage functions
function RVA_GetProgressMessage(Operation: TRVLongOperation;
  ControlPanel: TComponent=nil): TRVALocString;
function RVA_GetPrintingMessage(PageCompleted: Integer;
  Step:TRVPrintingStep;
If ControlPanel is a TRVAControlPanel component, the functions use it. Otherwise, they use MainRVAControlPanel.
RVA_GetProgressMessage returns a localized text message describing the specified long operation. It can be used in TRichViewEdit.OnProgress event.
RVA_GetPrintingMessage returns a localized text message describing the current printing progress. It can be used in TRVPrint.OnSendingToPrinter event.
The name of the current language is returned as ControlPanel.Language, or by RVA_GetLanguageName function.
The current language can be changed by assigning a new value to ControlPanel.Language, or by calling RVA_SwitchLanguage procedure.
Example:
This example assumes that Application.Hint is displayed in a status bar.
// TRVAControlPanel.OnDownload
procedure TForm3.RVAControlPanel1Download(Sender: TrvAction;
  const Source: TRVUnicodeString);
  if Source='' then
    Application.Hint := ''
    Application.Hint := Format(RVA_GetS(rvam_msg_Downloading),
      [Source]);
// TRVPrint.OnSendingToPrinter
procedure TForm3.RVPrint1SendingToPrinter(Sender: TCustomRichView;
  PageCompleted: Integer; Step: TRVPrintingStep);
  Application.Hint := RVA_GetPrintingMessage(PageCompleted, Step);
// Reading or writing
procedure TForm3.RichViewEdit1Progress(Sender: TCustomRichView;
  Operation: TRVLongOperation; Stage: TRVProgressStage;
  PercentDone: Byte);
  case Stage of
    rvpstgStarting:
        ProgressBar1.Position := 0;
        ProgressBar1.Visible := True;
        Application.Hint := RVA_GetProgressMessage(Operation);
    rvpstgRunning:
        ProgressBar1.Position := PercentDone;
        ProgressBar1.Update;
    rvpstgEnding:
        Application.Hint := '';
        ProgressBar1.Visible := False;
