RVA_SwitchLanguage procedure
Changes the current language.
procedure RVA_SwitchLanguage(const LanguageName: TRVALanguageName;
  ControlPanel: TComponent=nil);
If ControlPanel is a TRVAControlPanel component, the function uses it. Otherwise, it uses MainRVAControlPanel.
Assigning a new value to ControlPanel.Language has the same effect.
To get a list of valid languages, use RVA_EnumLanguages or RVA_FillLanguageList.
You can use either English or native language name as a parameter.
To complete a language changing, the following procedures must be called after RVA_SwitchLanguage:
RVA_LocalizeForm for localization of Captions and Hints of all actions on the given form/datamodule;
RVALocalizeRuler for localizations of hints in TRVRuler component;
RVA_GetCharset for changing Charsets of menus, hints and your forms;
RVA_GetS for localizing standard menu items in your menu (such as "File", "Edit"...).
See also:
RVA_ChooseLanguage
