       << Click to display table of contents >> TSRVViewProperty.MarginsPen |
Specifies a pen properties for drawing rectangle around the document area.
property BoundTextPen: TSRVMarginsPen;
This rectangle shows margins. It is drawn only if MarginsRectVisible=True.
In Delphi XE2 or newer, if a system color is specified for MarginsPen.Color, and custom styles are applied, then a corresponding style color is used instead.
Default value:
psDot, clSilver
