       << Click to display table of contents >> TSRVViewProperty.HeaderPen |
A pen for drawing a line between the main document and the header, when a header (TSRichViewEdit.RVHeader) is being edited.
type
TSRVHeaderFooterPen = class (TPen);
property HeaderPen: TSRVHeaderFooterPen;
The color of this pen is also used for drawing border around header label, see Texts.
In Delphi XE2 or newer, if a system color is specified for HeaderPen.Color, and custom styles are applied, then a corresponding style color is used instead.
Default value:
1, psDot, $00CA784B
See also:
