       << Click to display table of contents >> TSRVToolWindow.ImageList |
A reference to image list for images in tool buttons.
property ImageList: TCustomImageList;
This image list must contain buttons glyphs for all buttons states (normal, pressed, disabled) (you can use the same image for all of them).
When a toolbar displayed on a monitor that has pixel density (DPI) higher than 96, the toolbar draws images stretched, proportionally to the screen DPI. To turn off stretching, assign ScaleImagesForDPI = False.
