       << Click to display table of contents >> TSRVToolButton.Enabled |
Controls whether the button responds to mouse and keyboard events.
property Enabled : Boolean;
Use Enabled to change the availability of the button to the user. To disable a button, set Enabled to False.
Default value:
False
