       << Click to display table of contents >> TSRVToolBar.Spacer |
Specifies the distance between tool buttons.
property Spacer: TRVPixel96Length;
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
0
