       << Click to display table of contents >> TSRVTabSet.MaxTabSize |
Specifies the maximum allowed tab width.
property MaxTabSize: TRVPixel96Length;
For horizontal tab set controls, this property defines a maximum width of tabs.
For vertical tab set controls, this property defines a maximum height of tabs.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
200
See also:
