       << Click to display table of contents >> TSRVScrollBar.PageSize |
Specifies the size of the thumb tab.
property PageSize: Integer;
PageSize is the size of the thumb tab, measured in the same units as Position, Min, and Max (not pixels).
0 means the default size.
Default value
0
