       << Click to display table of contents >> TSRVDrawScrollBarAreaEvent Type |
A type of the following events of TSRVScrollBar:
Unit SRVSBar.
type
TSRVDrawScrollBarAreaEvent = procedure(Sender: TSRVScrollBar;
Canvas: TCanvas; ARect, PaintRect: TRect; isFirstArea: Boolean;
State: TSRVDrawStates; var DoDefault : Boolean) of object;
Parameters
Canvas – a canvas where to draw.
ARect – a rectangle defining the position of the object to draw.
APaintRect – a rectangle that needs to be redrawn. You can use this parameter to optimize drawing.
isFirstArea – True if this event is called for the background area between the "dec button" and the thumb tab.
State – a set describing the current object state.
Set DoDefault to False to prevent the default drawing of this object.
