       << Click to display table of contents >> TSRVCloseButton.IndentY |
Specifies the vertical indent added to the button position.
property IndentY: TRVPixel96Length;
If VerticalAlign=srvthaBottom, the button is shifted to the top by this value. Otherwise, it is shifted to the bottom.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
3
