       << Click to display table of contents >> TSRVBackgroundProperty.Visible |
Disables/enables background displaying.
property Visible : Boolean;
If the value is False, all properties of this class are ignored and background is filled with TSRichViewEdit.Color.
A zooming panel is always filled according to BackgroundProperty, even if Visible=False.
Default value:
False
