       << Click to display table of contents >> TsrvActionCustomLayout.OnExecuted |
Occurs after the action applies the layout
property OnExecuted: TNotifyEvent;
This event may be useful if you have buttons for document view modes in the scrollbar area of TSRichViewEdit control.
You can use this event to synchronize buttons with the actions.
Example:
(assuming that the buttons are in the following order: draft, web layout, print layout)
// SRichViewEdit1.OnHMenuClickButton
procedure TfrmMain.SRichViewEdit1HMenuClickButton(Sender: TObject;
ToolButton: TSRVToolButton);
if ToolButton = nil then Exit;
SRichViewEdit1.CanUpdate := False;
case (ToolButton.Index) of
0 : srvActionLayoutDraft1.Execute;
1 : srvActionLayoutWeb1.Execute;
2 : srvActionLayoutPrint1.Execute;
3 : srvActionLayoutSideToSide1.Execute;
4 : srvActionLayoutRead1.Execute;
ActiveEditor.CanUpdate := True;
// After doc view actions are executed
procedure TfrmMain.srvActionLayoutDraft1Executed(Sender: TObject);
TSRVToolButton(SRichViewEdit1.MenuHButtons.Items[0]).Down :=
True;
procedure TfrmMain.srvActionLayoutWeb1Executed(Sender: TObject);
TSRVToolButton(SRichViewEdit1.MenuHButtons.Items[1]).Down :=
True;
procedure TfrmMain.srvActionLayoutPrint1Executed(Sender: TObject);
TSRVToolButton(SRichViewEdit1.MenuHButtons.Items[2]).Down :=
True;
