       << Click to display table of contents >> TSRichViewEdit.OnStyleConversion |
Occurs while executing ApplyStyleConversion method of RichViewEdit, RVHeader, RVFooter, or RVNote (these TRichViewEdit controls are specified in the Sender parameter)
property OnStyleConversion: TRVStyleConversionEvent;
This event allows you to create custom conversion procedure of text styles for the selected text. This event is called for all selected text items allowing to change their text style.
It can be useful to implement commands like "make bold", "apply font", "change text color", etc.
See the event of the same name in the TRichView help file (event of TCustomRichViewEdit).
See also:
