       << Click to display table of contents >> TSRichViewEdit.OnSmartPopupClick |
Occurs when user clicks "smart popup" button.
property OnSmartPopupClick: TRVSmartPopupClickEvent;
This event allows implementing your own effect when clicking "smart popup" button (or on pressing its ShortCut). If you use menu, it's not necessary to process this event.
See also:
