TRVReportRecordCountMode
Unit RVReportDBDataProvider;
Syntax
type
  TRVReportRecordCountMode =
    (rvrrcmDoNotUse,
     rvrrcmUseIfAvailable,
     rvrrcmUseAlways);
Value
Meaning
rvrrcmDoNotUse
Report Workshop avoids using DataSet.RecordCount property.
If possible, unidirectional datasets are created in this mode.
If Report Workshop needs a second pass through the results of DataSet, it closes and re-opens the dataset before moving to the first record.
Pros:
•queries may be executed faster;
Contras:
•Report Workshop still requires record count for some operations (if RowGenerationRule.CopyColCount > 1, or for cross-tab reports); in this case, one more query execution is added to calculate the record count;
•some operations are performed less efficiently; for example, when applying queries to table rows, rows are added one by one instead of adding all rows at once;
•OnDataQueryProgress is called without calculating Percent parameter
Report Workshop uses DataSet.RecordCount property. It assumes that the dataset correctly processes First, Next, and Last commands.
This value cannot be used for unidirectional datasets that cannot move back to the first record.
rvrrcmUseAlways
When opening a dataset for the first time, one more query execution is performed to calculate record count. After that, the dataset is closed and re-opened.
