TRVMotionDetector.MinChangeAreaSize, PixelColorThreshold -R -G -B
The properties specify the parameters used to compare video frames.
property  MinChangeAreaSize: Integer;
property PixelColorThreshold: Integer;
property PixelColorThresholdR: Integer;
property PixelColorThresholdG: Integer;
property PixelColorThresholdB: Integer;
The motion detector compares two images (usually video frames).
Let the first pixel is (R1 G1 B1), the second pixel is (R2 G2 B2). If PixelColorThreshold >= 0, they are treated as different if (|R1-R2| + |G1-G2| + |B1-B2|)/3 > PixelColorThreshold. Otherwise, they are treated as different if (|R1-R2| > PixelColorThresholdR) or (|G1-G2| > PixelColorThresholdG) or (|B1-B2| > PixelColorThresholdB).
The component calculates rectangles covering changed pixels optimally. Rectangles containing less than MinChangeAreaSize changed pixels are ignored.
Default values
•MinChangeAreaSize: 10
•PixelColorThreshold -R, -G -B: 8
Default value
15
See also
•TRVCamSender.MinChangeAreaSize, PixelColorThreshold
