       << Click to display table of contents >> TRVMicrophoneView.OnPaint |
Allows to draw a custom image showing a sound volume.
type // defined in MRVType unit
TRVMicrophonePaintEvent = procedure(Sender : TObject;
Level : Integer) of object;
property OnPaint: TRVMicrophonePaintEvent;
This event is used in Style=rvmpsOwnerDraw.
The sound volume can be calculated basing on the Level parameter as |Level-127|.
