TRVChangedAreaProcessingMode
Specifies how video frames are preprocessed before detecting changed areas
Unit [VCL and LCL] MRVFuncImg;
Unit [FMX] fmxMRVFuncImg;
type
  TRVChangedAreaProcessingMode = (rvcapmOriginalSize, rvcapmAuto);
Value
Meaning
rvcapmOriginalSize
Changed areas are searched in the original video frame
rvcapmAuto
A video frame is shrunk before processing. The largest side of the frame is reduced by half until it becomes >= 320 pixels. The smallest side is reduced accordingly.
Searching for changed areas may be a time consuming process in large frames. Working with reduced images allows to make processing fast.
This type is used for the properties:
•TRVCamSender.ChangedAreaProcessingMode
•TRVMotionDetector.ChangedAreaProcessingMode
