       << Click to display table of contents >> TRVCamView.UseOptimalVideoResolution |
Indicates whether the control tries to set the video resolution which is optimal for its size.
property UseOptimalVideoResolution;
This property works if VideoSource is TRVCamera. If True, the control assigns VideoSource.VideoResolution calculated using VideoSource.GetOptimalVideoResolution, specifying its size in the parameters.
Default value
False
