       << Click to display table of contents >> TRVCamView.OnPaint |
Occurs when the component needs to paint a video frame.
type // defined in MRVType unit
TRVCamPaintEvent = procedure(Sender : TObject; VideoFrame : TBitmap;
ACanvas : TCanvas; var CanDrawFrame : Boolean) of object;
property OnPaint: TRVCamPaintEvent;
Parameters
VideoFrame – a bitmap image containing a video frame to draw.
Canvas – a canvas where you can draw. However, the recommended way to use this event is modifying VideoFrame.
CanDrawFrame specifies whether the component should draw VideoFrame onto Canvas.
