       << Click to display table of contents >> TRVCamSound.OnGetAudioStreamIndex |
Allows to choose an audio stream to play.
property OnGetAudioStreamIndex: TRVGetMediaStreamIndexEvent;
This event occurs before playing a video file.
This event may be useful if a video source contains more than one audio stream.
If the event is not processed, the first audio stream is played.
Warning: this event is called in a thread context.
You cannot change an audio stream while the video is played: you need to restart video.
See also
