       << Click to display table of contents >> TRVCamSender.VideoSendType |
Specifies how video is sent.
type
  TRVMVideoSendType = (rvmvstImageStream, rvmvstVideoStream);
property VideoSendType : TRVMVideoSendType;
Value  |
Meaning  |
rvmvstImageStream  |
Frames are sent separately. A connection is established for sending each frame. Several frames can be sent in parallel.  |
rvmvstVideoStream  |
Frames are sent in a single connection. This connection is closed only when video is finished. Recommended for slow processors.  |
This property is used when a sender is connected to a receiver. Otherwise, a permanent connection is always established.
Default value:
rvmvstImageStream
