TRVCamSender.OnEncodeVideo
Occurs when sender is about to send a video frame from VideoSource (or ExtraMediaSources)
You can use this event to compress or encrypt video data.
type // defined in MRVType unit
  TRVEncodeVideoEvent = procedure(Sender: TObject;
    AStream: TMemoryStream;
    var ADataSize: Integer; AVideoIndex: Word;
    ImageType: Byte) of object;
property OnEncodeVideo: TRVEncodeVideoEvent;
AStream contains a video frame. Only initial ADataSize bytes in this stream are used.
AVideoIndex identifies the audio source (0 for VideoSource, 1 or greater for ExtraMediaSources).
The format of data in AStream is identified by ImageType parameter. It may be one of:
  rvtiJPEG = 1;
  rvtiHWL = 2;
  rvtiBMP = 3;
  rvtiPNG = 4;
If the sender sends changed areas, this event is called for every changed area on a video frame. Otherwise, it is called for the whole video frame.
You can encode a video data, and write it back to AStream. Update ADataSize accordingly.
See also:
•Encoding
•OnEncodeAudio
•TRVCamReceiver.OnDecodeVideo
