       << Click to display table of contents >> TRVCamReceiver.OnRequestJoinGroup |
Occurs in response to TRVCamSender.JoinGroup
type
  TRVJoinGroupEvent = procedure(Sender: TRVCamReceiver;
    SessionKey: TRVSessionKey; const GUIDGroup: TRVMAnsiString;
    const AAccess: Boolean; const AError: Integer) of object;
property OnRequestJoinGroup: TRVJoinGroupEvent;
This event occurs when a pair of TRVCamSender and TRVCamReceiver (inside a single application) is connected to TRVMediaServer via the network as a client.
TRVCamSender.JoinGroup requests to join the specified group on the server. The server sends this information to a receiver, and OnRequestJoinGroup occurs.
Parameters:
GUIDGroup – identifier of the group (the same as the parameter of TRVCamSender.JoinGroup)
AAccess – True if the user successfully (extended information can be received from AError parameter)
AError – error (or success) code.
AError Value  |
Meaning  |
RV_ERROR_CMD_SUCCESS  |
The user successfully joined the group (no error).  |
RV_ERROR_CMD_BAD_PASSWORD  |
The user did not join the group because the supplied password was incorrect.  |
RV_ERROR_CMD_GROUP_EXISTS  |
The user did not join the group because this group does not exist on the server.  |
If you perform time consuming operations inside an event, it makes sense to compare values of SessionKey parameter and SessionKey property, to make sure that a connection was not closed or reopened.
Warning: Do not display modal forms in this event.
See also:
