       << Click to display table of contents >> TRVCamReceiver.IgnoreCorruptedFrames |
Specifies how missing or corrupted frames are processed in a chain of frames.
property IgnoreCorruptedFrames: Boolean;
A chain of frames is sent, if a positive value is assigned to TRVCamSender.FrameDifferenceInterval. The first frame in a chain is sent as it is, subsequent frames are sent as differences between the new and the old frame.
This property specifies how the receiver works if one frame in a chain is missing or corrupt (it is possible in UDP connection).
If True, frames are still shown, but visual artifacts are possible.
If False, the rest of chain after a corrupted/missing frame is dropped.
Default value
False
