       << Click to display table of contents >> TRVCamMultiView.CamMoveMode |
Specifies how the selected viewer controls the camera motion.
property CamMoveMode: TRVCamMoveMode;
This property works if the viewer's VideoSource is TRVCamera. The user can control the camera motion (rotation) using the mouse, if supported by the camera.
Default value
vcmmDrag
See also:
•TRVCamControl component
