       << Click to display table of contents >> TRVCamera.Quality |
Defines the video quality preference, if the camera supports it.
type
// defined in MRVType unit
TRVQualityType = (qtStandard, qtFavorMotion, qtFavorClarity);
property Quality: TRVQualityType;
Value  |
Meaning  |
qtStandard  |
standard quality  |
qtFavorMotion  |
optimizing for a fast motion  |
qtFavorClarity  |
optimizing for a quality static video frames  |
If the camera supports this property, its value is received from the camera when the component is connected to it, see SearchCamera.
Default value
qtStandard
