       << Click to display table of contents >> TRVCamera.GetColorControlPropertyRange |
Returns a range, a default value and a step size for the specified property.
function GetColorControlPropertyRange(Prop: TRVColorControlProperty;
  out MinValue, MaxValue, DefValue, Step: Integer): Boolean;
The function returns True if the selected camera supports the specified property.
You can use the results when assigning values to Brightness, Contrast, Saturation, Sharpness, Hue properties.
Input parameter:
Prop – property (brightness / contrast / saturation / sharpness / hue).
Output parameters:
MinValue, MaxValue – minimum and maximum allowed property values.
DefValue – default (neutral) property value.
Step – step size for the property (the smallest increment by which the property can change).
