       << Click to display table of contents >> TRVCamera.FocusType, FocusDistance |
The properties control the camera focus, it the camera supports it.
type
// defined in MRVType unit
TRVCamFocus = (rvcfFocusAuto, rvcfFocusNear, rvcfFocusFar);
property FocusType: TRVCamFocus;
property FocusDistance: Integer;
These properties are supported for Panasonic cameras (see SearchCamera). These are write-only properties: RVMedia cannot read these properties from the camera, but can assign them.
FocusType:
Value  |
Meaning  |
rvcfFocusAuto  |
automatic focus  |
rvcfFocusNear  |
focus near  |
rvcfFocusFar  |
focus far  |
FocusDistance is used only if FocusType<>rvcfFocusAuto. Possible values:
Value  |
Meaning  |
1  |
small displacement  |
2  |
large displacement  |
FocusType is not supported
FocusDistance can be get and set (for cameras that support it). Minimum and maximum values depend on the driver.
Default values
•FocusType: rvcfFocusAuto
•FocusDistance: 1
